7 bolt block difference 95-97 98/99 anyone have pictures?
ApexVIII
812
5
Jan 12, 2008
Modesto, California
anyone have pictures of the difference of 95/97 vs the newer 98/99 blocks?
Here are some pics of my 98 turbo block showing the thrust bearing.
thanks! is there anyway to tell if you have a 95-97 block sitting right next to a 98/99? like casting numbers
i thought i read some one say that the 95-97 have a skinnier thrust bearing journal then the 98/99 do is that true?
Actually it's not your block anymore. :D
I just received your old block today.
The bores are in excellent condition as you stated, and the main bearings really show no signs of excessive wear. :thumb:
The half moon thrust washer is shown here.
The thrust washer fits into the machined relief in the block shown here.
The two parallel ends of the thrust washer sit about flush with the parting line and lock against the girdle main cap.
The thrust washer must be thicker than the step in the girdle main cap, or we'd have real issues.
Below is a pic taken directly from CAPS.
It clearly shows the Thrust Washers on the block side of the crank, and one on each side of the journal.
