Login
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Cylinder Head & Short Block
Cylinder Head & Short Block Cams, valvetrain, pistons, rods, stroker kits, 6-bolt swaps, hybrids, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 07-10-2009, 12:59 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
Proven Member
Tech Posts: 95
Classifieds Rating: 0
Reputation: decathect is more helpful than not
Oil relief valve causing low oil pressure?
I have heard of this valve failing, causing HIGH oil pressure, but can failure cause low oil pressure? I have low oil pressure primarily when the car is very warm, at idle. Is it even worth looking at?
Does anyone know more about precisely when this valve should be open, and when it should be closed?
Advertisement
To browse the forums without the advertisements above, Login/Register
Old 07-10-2009, 01:05 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
Proven Member
Bud92gsx's Avatar
Tech Posts: 884
Photos: 6
Classifieds Rating: 1
Reputation: Bud92gsx is more helpful than not
Low oil pressure whe warm at idle is normal...I mean not like minimal but under the little line? Your not on the throttle, the oil pressure is going to drop..
____________________________
92 6/4 Auto EVO 3 16G
My Turbo Is My Radio
View photos of this member's car
Old 07-10-2009, 01:41 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
Proven Member
Tech Posts: 95
Right. Its too low. Its causing my car to register knock due to extra engine noise from low oil pressure.
I'm not asking for input on whether or not I have low oil pressure, at this point I'm wondering if it is the relief valve COULD be causing this.
Old 07-10-2009, 07:48 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
Proven Member
BogusSVO's Avatar
Car: 1985 Thunderbird Turbo Coupe
Tech Posts: 381
Reputation: BogusSVO is pretty helpful and trustworthyBogusSVO is pretty helpful and trustworthy
if the relife spring is weak or broken it will allow the oil pressure to bleed off before it is needed too
Old 07-10-2009, 10:46 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
Proven Member
Tech Posts: 95
Under normal operation, when SHOULD that valve open?
Old 07-10-2009, 12:07 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
Proven Member
Bud92gsx's Avatar
Tech Posts: 884
Photos: 6
When there is too much pressure in the crank case, the pcv valve will releive pressure..Unscrew it and clean it out with brake clean or something..
I wouldnt think that it's your oil pump, cause if that was the case you probly wouldnt have oil pressure in the 1st place..Then boom..
Old 07-10-2009, 02:24 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #7 (permalink)
Proven Member
Tech Posts: 95
I dont think you understand the relief valve. It is separate from the PCV system.
Old 07-10-2009, 02:42 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #8 (permalink)
Proven Member
turboglenn's Avatar
Tech Posts: 2,840
Classifieds Rating: 4
Reputation: turboglenn is extremely helpful and trustworthyturboglenn is extremely helpful and trustworthyturboglenn is extremely helpful and trustworthy
I'm pretty sure the reliefe valve is supposed to open at 60psi, the general rule of thumb for oil pressure is 10psi for every 1000 RPM of engine speed...I.E. at 3500 you should have at least 35psi of oil pressure (or more) With balace shafts removed you usually have to port the OFH releif valve to bring it back under control...never heard of one causein low pressure, you might want to check the pump, bearing cleanrnaces etc...if you really think it's too low.
The stock gauge is junk, it to me is only to tell if i have pressure or not...definately not for an accurate reading. Stock my OEM gauge would sit at the bottom line at idle then hover about 3/4 the way up at highway speeds. after putting in a real guage it's apparent that the OEM unit is pure junk.
Visit turboglenn's homepage!
Old 07-10-2009, 03:28 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #9 (permalink)
Proven Member
dsmfa9nutter's Avatar
Car: 1990 Dodge Colt
Tech Posts: 607
Photos: 5
Reputation: dsmfa9nutter is more helpful than not
^Probably electrical. Mechanical oil pressure gauges are dangerous as hell and aren't legal at any track.
OP, get a real oil pressure gauge. I run around 30psi at 1krpm to over 110 when cold and then back to around 90 at wot when warm. This is with BSE and no relief valve porting.
Visit dsmfa9nutter's homepage!  View photos of this member's car
Old 07-10-2009, 03:37 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #10 (permalink)
Proven Member
lacroixdp's Avatar
Tech Posts: 685
Photos: 1
Reputation: lacroixdp is pretty helpful and trustworthy
These oil pumps are extremely robust... I would not suspect that as a failure, at least not at first. The relief valve would have to be stuck in the open position to cause this problem... I doubt that's the case as well. Most of the time, they get stuck in the completely closed position, not vice versa. Get a oil pressure gauge from HF and check it at the head. If it really is low, then you can unbolt that relief valve on your oil housing and check it if you'd like. If you're getting knocking, it's possible you've spun a bearing or you just have plain old excessive bearing play causing your low pressure. You could easily check this by dropping your pan and removing a main. If your gear bolt for the oil pump fell off, it would cause you to lose massive amounts of oil, which obviously would affect your pressure. Good luck!
Ryan
Old 07-10-2009, 03:59 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #11 (permalink)
Proven Member
Tech Posts: 95
thank you for the helpful responses. I'm a bit mystified myself as to the cause of the low oil pressure. I am going to install a oil psi gauge soon to find out, but i'm 99.9% certain low oil pressure is causing the problem i'm having, due to the nature of the problem. I'll post up once I get oil pressure readings.
Old 07-19-2009, 08:56 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #12 (permalink)
Proven Member
Tech Posts: 95
Alright, I was wrong! Dangit, that never happens!
My stock oil sensor or gauge must be bad, because I hooked up a digital oil pressure gauge, and my readings are as follows:
Warm idle: 15-18 psi
Cruising at 3k RPM: 75 psi
Cold idle: 25-30
Cold, cruising at 3k RPM: ~90 psi
Seems alright to me? Back to the drawing board on this phantom knock thing. Its weird, I get knock when the car is warm, oil pressure is lowest, and I do like a 1st or 2nd gear pull. Once the oil pressure rises up, it stops knocking. Any suggestions on why this might be happening?
Old 07-19-2009, 08:58 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #13 (permalink)
Proven Member
lacroixdp's Avatar
Tech Posts: 685
Photos: 1
Take the readings from the head. Those are from the OFH.
Ryan
Old 07-19-2009, 09:47 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #14 (permalink)
Proven Member
Tech Posts: 95
Yes, those readings are from the OFH, that's also where the stock sensor is. I've never been told to hook my gauge up to the head. Isn't there a restrictor that limits oil pressure to the head to be like 20-30 psi? Or are you saying I should just see what it is at the head, to determine if the head is getting enough oil? I'm unsure why you want me to do this.
note, by knocking, i mean my logger is registering knock. Not that I can hear an audible knock sound when I rev the engine. I know what a spun bearing sounds like.
Reply
Bookmarks
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
oil pressure relief valve? staflo500 Newbie Forum 18 04-04-2009 04:41 PM
Oil Pressure Relief Valve Porting knochgoon24 Articles: Engine & Fuel 0 12-23-2008 01:02 AM
high oil pressure after porting oil relief valve jw_55_55 Newbie Forum 21 08-05-2008 09:08 PM
FP Green / Oil from Housing / Restrict Pressure? Port Oil Relief Valve? LaN- Turbo System Tech 8 05-11-2007 11:38 AM
Spring in 90 Oil filter housing. Oil cooler bypass valve or pressure relief? dragrush Bolt-on Tech 13 09-25-2006 12:00 AM
» Recent Tech Threads
Title, Username, & Date
New FP turbo
by: tsitalon03
need help running rich with 255
by: hondaslayer1
4 bolt rear
by: spitefire1
Logging Question
by: 95GreenGSX
Ebay XTD stage 3 clutch and flywheel
by: dale187
» Latest Gallery Photo
User evil_gsT
» Advertisement
» Current Poll
Which is your favorite addition to the site?
New Video Section - 20.73%
17 Votes
New Regional Forums - 19.51%
16 Votes
New Profile Pages - 20.73%
17 Votes
New Profile Messaging - 8.54%
7 Votes
New Classifieds - 30.49%
25 Votes
Total Votes: 82
You may not vote on this poll.
Powered by vBadvanced CMPS CMPS v3.2.1
DSM Forums | Pontiac Solstice/Saturn Sky Forums
© 2009 SPEEDtuners Network, LLC All Rights Reserved
Search Engine Optimization by vBSEO 3.3.1
