3KGT Stock Parts. What Ones Can Be...
mrfloppy
121
Aug 3, 2002
Does anyone know what stock parts you can use off of a 3KGT?
Could I use the fuel pump? If so, how much better does it flow then the stock turbo one for a DSM. I am looking for #'s..... not a response saying " It flows alot more. "
Is there anything else we can use from them?
Erik
I believe it flows 180-190lph on the 3kgt fuel pump, and yes you can use it.
What does stock flow?
Is it worth it to pick up a 3kGT pump or go for a Supra FP?
What does the Supra flow?
Is ether one harder then the other to install? Special tools, etc.
Also. Can I get any 3KGT pump or do I have to get the VR4/TT pump for the added flow.
Erik
100lph, so it's a nice upgrade.
Donno, but I'd be willing to bet it'd be cheeper to go with one from a 3KGT. I'm running a 190lph pump in the GSX with my 16G @ 18psi with no problems. Could use an aftermarket Feul Pressure Regulator though. Something I also want to try is stealing a stock FPR off a Supra/3K to see if it will work in our cars.
Also. Can I get any 3KGT pump or do I have to get the VR4/TT pump for the added flow?
It's a direct bolt in. There aren't too many internal (in the take) pumps that require any mods to the housing. Here's how you do it. http://www.vfaq.com/mods/pump-WB-1GAWD-print.html
I'd recomend rewiring it (if you haven't already) at the same time so you get the full 12V to it. http://www.vfaq.com/mods/pump-relay.html
Front brakes for the '90-mid year '92 AWD's/ all FWD 1G's. Just make sure the 3000 isn't a TT.
Mike C.
You can use the BOV. It will hold more boost and not leak like the stock 2G BOV. Also, you don't need an adapter or new UICP, it pops right in. Unfortunately, it doesn't work with most of the aftermarket UICP if you are planning on uprgading that eventually.
