dead_95tsi
- 39
- Aug 8, 2003
I've been looking for a 6 bolt block to swap into my walk'n 2nd gen. Will I be able to use the block of a 1992 galant n/t? Is the galant engine the same as a 420a? If it is the same as the 420a... will I be able to use the block for the swap. I searched and it seems the only thing different between the 420a block is the oil squirters and pistons/rods which i will be replacing in a rebuild. Will the block be able to support a large turbo as good as a 4g63 6 bolt block? Thanks
