Need a hose for BOV application
Puke
57
Apr 7, 2002
nope,
What's up all??
OK, anybody have any good custom hose manufactering web sites?
Here's the situation: I got a new UIC pipe, HKS SSQBOV, and the HKS recirculation kit. The new UIC pipe has the flange welded on the bottom side of the pipe as opposed to the stock location on the top. This is good as I know it will not rub the hood, but I need to find a hose that will connect the BOV to the intake hose for recirculation. The hose that the kit came with will not work even if I hack it. I need a hose with one end at a diameter of approx. 1"(that is what the recirc. hose diameter is) and the other end needs to be approx. 1.25" in diameter. It also needs to be an 'S' shaped hose as opposed to the 'U' shaped hose the recirc. kit came with. The hose could even be 'S' shaped with the outlets being approx. 90degs. apart(when looking at the top of the hose, hard to explain w/o a pic).
The recirc. kit comes with 2 recirc. fittings, one for the BOV itself and one for the STOCK intake hose. I have the aluminum intake pipe and therefore the recirc. fitting will not work. That is reason I need the hose to be larger on one end.
Any information is appreciated and thanks in advance!!
Sorry, guess I should have posted that in my original post. Went to many autoparts stores and couldn't find anything that will meet my needs. The only thing that I can think is that I need to buy 2 hoses and find some kind of plastic piece that will connect both together.. Yeah, it sucks!!
