Turbo Recommendation for my 95 TSi?
98TsiAWD
DSM Wiseman
2,861
8
May 19, 2002
94 3000GT VR-4, North Dakota
Here is what I plan to run:
DSMlink
6 bolt block/crank/rods
95 pistons
780 ExtremePSI injectors
255lph pump
Dejontool "Race" FMIC kit
93 Head/Intake/TB
1g speed cams
Ported 2g exhaust manifold
Dejon 3" Intake Pipe
TurboXS RFL BOV with recirculation fitting
I want to be able to hit 400whp or very close to if I have a DSMgod tune the car on 93 pump.
I donot have funds to buy a full garret setup right now.
I am willing to spend ~$1200 total for the turbo and install kit (oil feed,drain, etc) I want to run an internal wastegate also.
Recommendation?
I was thinking of a PTE possibly.
I see on their site they have a SCM50. With the choice of 69 or 76 Turbine wheels. Then under A/R is says TBD. Does that stand for To be determined, so I could chose .63AR? If so I think I already made my decision unless someone has a better idea?
Well, for 400 whp on pump, or just high horsepower on pump in general, I would say that anything with a 50-trim compressor wheel is your best bet. That gives you several options from PTE, the FP Green, at least one AGP turbo, and you can look at places SBR for slightly cheaper alternatives.
Something like this: http://www.slowboyracing.com/Garrett_Hybrid/G-50/SBR-G-50.html
Or, if you want to spend an extra couple hundred bucks for a REAL turbo, look into SBR's GT series stuff. Yummy.
...Kyle T.
93 TSi AWD "TURBO4"
14b - 12.8 @ 108
SBR-GT12... it will be mine, oh yes, it will be mine
