What color is the 02 signal wire for a/f gauge
There is a better and easier way to do this. On the passenger side. There is a kick panel. There should be a female conector, with one wire going to it. It will be tucked up there, and probley taped. Its the diagnositic port for the o2 sensor. Just run the wire across, put on a male connector, and plug it in. Easy, clean, and no hackin wires:thumb:
the easiest way on 2gs is how i told him to. It doesnt get much simplier then splicing a wire into the ecu. The diagram i gave him is very straight forward.
