UICP question
1997gstterror
59
Dec 26, 2002
Rosedale, Maryland
I want to upgrade my upper intercooler piping. now I want the full pipe from the stock intercooler to the throttle body, not one of the cheap halfway pipes that makes you keep your flex pipe. can u guys tell me where i can get this pipe for the best price? thanks
RRE and Dejon tool have them but they arent solid, RRE's uses a piece of your factory flex pipe, and Dejon uses a silicone connector but both go from the IC to the TB. By the way if you scroll up there is a link that says Parts Guide, it has just about everything manufactured for a DSM.
I could use more motor mount support :) They way you say it though makes it sound like it's a bad thing :)
I like the plastic ones, lighter then metal :) If the damn thing just didn't flatten out :(
:laugh:
That brode pipe looks nice and also cheap. I think I'll pick one of those up this spring... Is it beaded to prevent the hoses from blowing off?
the end near the BOV flange is beaded. the other end is not, but two clamps are supplied with it. haven't had a problem with it at all
I also have the Dave brode UICP, and I was thinking of getting the Dejon Tool "S" UIC Pipe, do they connect well together??????
Yes, the two do connect well with each other. The Brode doesn't have a lot of length after the flange but there is enough to get a good seal. I made sure to ask Dejon for a longer coupling when I ordered and that made it go on rather easily.
It might just be me but doesn't it seem like a waste to upgrade the lower pipes and 2nd upper icp if your using a turbo smaller then a 20g?
not only that, but the stocker has about 5 (sharp) bends instead of one lesser angle bend
When you upgrade the UICP. you will notice a hell of a difference, I did, in my opinion it was the only mod that I've done that I actually notice a big difference
