HyperGSX
- 1,170
- 1
- Oct 10, 2002
Schaumburg,
Illinois
Who is still running a 50 trim on their stock 6/7 bolt? How many miles have you put on this setup?
I used to daily drive my stock 6 bolt with a bolt up 50 trim and supporters running 20 psi. Loved that turbo, spooled nice and quick and still pulled hard. Upgraded to a 60 trim and never looked back though.Yep I ran a 50 trim on my stock 7bolt for 2 years and have since moved on to a GT3561.
Had my BB 50 trim for a year,but put cams and manifold and goodbye 7 bolt. Lasted 2 days.
New pics of setup or ban
Nothing Special just a bolt-on Internal gate PTE GT3561, been running it all year.
Ran a 12.2 at 123 with driving issues and last time out at the track I ran a 12.1 at 113 with Horsepower issues, I have a feeling the stock 7bolt is down on compression but I haven't tested it yet, also the TOB took a dump so i can't even drive the car.
I May just have to do a Twin disc and Stroker over the winter...
Sorry to dig up an old thread but I am thinking about going a 50 trim route over the EVO 3 16g. My question is when all you guys refer to your engine being "stock" do you mean it has not been built or modified in any way? Basically, are these engines stock everything including head gasket and studs? Thanks for any replies out there!!
It was actually a mix of 110 and 94, I was at 26psi and maybe 15 degree's of timing. I was picking up 1-1.5mph for every degree of timing so the car had easy 125's at 26psi. Also boost holds rock solid down to the tenth of a Psi.
6 bolt is good to 600+ whp.. No limit really found yet
7 bolt is good to 500+ whp.. have yet to push the limits
