oil pressure????
mechanical and ull have a running, warm oil line in the cabin....but deadly accurate
electric and ull have a wiring running from a sender inside ur engine bay....accurate, but not as quick responsing as the mechanical, but still accurate....get this 1 to reduce hazards and avoid possible oil leaks in cabin.
i have a mechanical gauge... i like it.. plus i like the full sweep... only prob is i did break the oil line once... not the cabin side... the part that goes to the oil pressure sender under engine. kinda sucked but it was only a $0.10 fix.
okay, when i first start the car(when its 20 degrees out) it goes to 50, but then after it warms up it goes to 0 when i'm not on the gas. when i'm on the gas it goes to 20 psi. wuts going on with it(like is it normal)?????? thanks for all the help
mike
if you take it from the head , it will usually only go to 50 psi or less due to a reilef spring in the head, instead take the oil psi from the oil housing and you will get much higher readings. i averaged 40 at idle and 110or so @ 2500rpm +
