Polk
- 91
- 2
- May 9, 2002
As a lot of you guys may already know we build chromoly lower control arms for the 1Gs'. I have had a ton of people wanting something for the 2G's. The 2G's have a similar set up of a Honda and have a ton of wheel hop.
It will be made out of chromoly and should not be any higher than $450. I hope I will able to manufacture then a little easier than the 1G's making them less $$$.
I hope to have a set or two done well before Christmas. Let me know how many of you guys may want something like this.
One last thing. We are almost done with a chromoly front cross member. It will weigh somewhere in the neighborhood 1/3 less than the factory one and have solid aluminum body mounts instead of the factory rubber ones. We are also working on chromoly rear lower control arms for weight savings and be able to run a lot larger tire and deeper off set in the rear. These two items are for 1G's and someone serious about racing.
Let me know what you guys think.
Polk
Polk
I have the motor mount inserts, upgraded suspension, etc and I still get wheel hop. It was bad enough in June to shear the CASE in half on my speed design center diff
