Advantage/Disadvantage of a '90-'91 from a '92-'94 1G
Dieselboy
2,359
Nov 6, 2002
Seattle Area, Washington
Talons TSi (AWD) and Eclipse GSX 1G's, whats ALL the advantage/disadvantages about the '90-'91 apart from the '92-'94??? Problems, recalls, performance potential, EVERYTHING. Thanks
i heard 90-91 has better/stabler drivetrains!!!!!! not sure. the ones after that has a skrewed up drivetrain i heard.
90-91
pros
Always has a 6-bolt motor
Always has the better 3rd and 4th gear
Cheaper
cons
Always has older synchros that aren't as good
Always has a 3-bolt axle
90 has a bunch of weird sh|t that is different than any other year
Probably going to have more miles
Worse cams, worst on the 90s
92-94
pros
Most have 4-bolt axle
Most have updated syncros
Probably going to have less miles
Better cams, best on the 94s
cons
Most have have a stupid 7-bolt motor
Most have weaker 3rd and 4th gear
Originally posted by BatmanGSX
90-91
cons
#1)Always has older synchros that aren't as good
#2)Always has a 3-bolt axle
#3)90 has a bunch of weird sh|t that is different than any other year
#4)Worse cams, worst on the 90s
Questions
#1)Can I swap the synchros for newer ones, or just get the tranny rebuilt?
#2)Can I upgrade to a newer 4-bolt?
#3)Different like what?
#4)Can I swap these out for '94's or does HSK make cams for the '90-'91?
Thanks, sorry bout all the questions :D
Originally posted by Dieselboy
Questions
1) yes
2) yes
3) different TB, different cruise control, different CAS, different ECU (more stuff I forget)
4) yes, HKS makes cams for the 90-91. It's not worth swapping to another set of stock cams from a different year, they aren't that different
92 is the best year DSM. If you get really lucky you can get all the goodies... 6bolt motor, big brakes, 4 bolt rear end, & the better 3rd/4th gear. As long as you stay w/ the early 92s (built in 91) then you'll at least get everything but the big brakes... which are also the easiest/cheapest to retrofit. Also almost every 92 thats I've seen has had an EPROM ECU.
I thought big brakes came in 93.5. Even those are still shitty, if you are serious about braking you would ditch the "little brakes" or the "big brakes"
Originally posted by KenTSIII
"big brakes" w/ porterfield R4S pads actually work quite well.
I'm sure they work quite well in normal conditions but on a road course or even an AutoX they would still be a joke.
it's funny you guys think the brakes are so bad on these cars. the 91 i test drove yesterday felt great! but then again i am used to the breaks on my prelude and they are really really weak. even by honda standards.
My prelude's brakes were fine.. but then again, they were cross-drilled and slotted Brembo's with metal master pads ;) But I'd say everyone pretty much covered everything about the differences. 90's also have differently routed stock UICP and different trannys/(where the tranny cables are clipped on).
my car is a '91, and i believe its was manufactured in late. '90.
does that mean i have the "dual piston" biggest brakes in 1Gs? :p
