GSX4LIFE
- 709
- 30
- Aug 17, 2002
For the past 700 miles or so, I have been running about 20psi and getting full boost by about 38-3900rpm. Over the weekend i turned up the boost to 22psi(feels much stronger from only 2psi increase). And the other day I was messing around under hood, and descided to adjust the wastegate actuator rod(shorten it). This increases the pressure it takes to open the flapper door. I took I for a little spin. And, to my disbelief, Im now reaching 22psi by about 3600rpm! I cant believe it! This was in 4th gear, starting from about 2800rpm. Oh, and ask LarryD what the car looked like, coming in the parking lot full of DSMers after a run.
Ill say it again, this is one BAD AZZ turbo!!!
