Buschur MBC confusion!?
sweet97
2,386
18
Mar 6, 2004
auburn, New York
I believe I may have my lines reversed. I have the boost signal going to the top nipple and the line from the bottom nipple going to the wastegate actuator. I use a nipple on the turbo compressor housing outlet for the boost signal.
I get 13 PSI. Nothing more with MBC adjustment. The actuator must have a 13lb. spring.
My car is not yet street legal so I cannot spend much time on testing. I have taken it around the block. Working out the bugs from winter additions. Thanks, Mark
If it's a ball and spring type, the pressure source should be inline with the adjustment knob and the T fitting whould go to the actuator. Try bypassing the mbc and see if you get the same 13psi, make sure you don't have any boost leak.
I got a reply from the Buschur site and I got the lines reversed. A couple other of issues and weather will keep me from testing for a few days.Thanks
  • For sale 2g hatch panels
    Have right and left rear hatch panel and overhead hatch panel
    • mpedraza
  • Wanted 2g Ac tensioner
    Looking for ac tensioner and pulley for 2g
    • Simo_217
    • 92AWDHX40
    • eclipsemf
