Eff3ct
- 33
- Apr 3, 2009
Seattle,
Washington
So I picked up a sunroof today/ The motor on my old one would click on, but nothing happened, and I found this used one for 80 bucks, so I grabbed it.
Well I just put it in, and it was out of a 95 GSX, I have a 95 Talon tsi.
Hard to describe, so here's pictures to do the talking. It WORKS, and opens, raises, closes, etc. But the passenger side is really loose, and this:
Ok, well now Photobucket seems to be broken, and I can't upload pictures.
Well, the rear passenger corner, sticks up.
The entire half inch or so of the frame sticks above the roofline, where it should all be flat. Edit: This is only in the back rear passenger corner.
And when I sit inside with it closed, I can push that side up and down about another half an inch.
And then when it's open, I can wiggle the passenger side around quite a bit.
Annnnd lastly, the holes for the two screws and bolt by the switch, don't line up. Which means also, the little hole for that black box the switch is in, doesn't line up, so it can't tuck up into it.
And I don't know why, or what to really do, I don't think I can really shimmy it around enough to make them line up.
I'll try and get photobucket working to load these, it's hard to explain.
Edited for pic:
Sunroof059.jpg picture by drinkingjester - Photobucket Where it raises.
Sunroof066.jpg picture by drinkingjester - Photobucket Where the screws don't line up. :/
Edited for pic:
