valve cover! will i still work?
you could try can getting it fixed, you could try JB weld, to fill it in. i would look to see how bad it is with the valve cover gasket installed
it really dont seem that bad i would re use itput on some silicone over the new seal and bolt it up till you get time or another one to redo all your work on it, the crack dont look like its gone all the way through from what i can see just the outer lip
