LoTek Guage pods fitting prob.
nellystyle
211
Oct 12, 2002
manchester, Connecticut
i just had boost/air fuel guages put into my a pillar. and they work great, but the one problem is that it looks like they put the pillar over the existing pillar... now, correct me if i'm wrong but isn't it a replacement pillar? so the old one should come off? because when you look from the outside of the car through the windshield at the pillar, you can see that it is basically sagging, so i pushed on it real good, but i want it in there snug. just want to make sure that it's a replacement pod before i go pissing and moaning to them about wrong facts.
thanks again
it is a replacement. They should have taken off the stock pillar before attaching this one. Lo Tek makes very high qualit pods, if it doesn't fit, it is likely that the people you had attach it did something wrong. I would just do it yourself, as it is a very easy procedure.
thanks,
when you drilled it, did you just use 1 screw? and do you remember the number/ length of the screw? thanks again, just dont want it to go through the car
sounds like 'll just do it tomorrow
