Which gas station in Anchorage ?
907gs-t
1,494
6
Feb 3, 2009
Juneau, Alaska
Which gas station in Anchorage has the highest octane rating in town for Premium?
I've always used Chevron Premium wondering if there is one in town with a higher octane rating than just 90.
You can buy 104 and 115 (i believe) at the Tesoro on Muldoon. I do not think that they sell it during the winter though. During the summer that's always where I fill up on race gas before heading to the track. I tune on my way out to the track and by the time I get out there I am sitting at my 1/2 full tank. Works perfectly.
As far as just "premium" grade...every station in town sells 90. If you want to boost octane you'll have to use some Torco.
I too only fill at Chevron stations. I run the FIC ball/disc type injectors and unless I run Chevron gas the injectors like to act up. I run chevron injector cleaner every few tanks of gas as well. We sure do have some shitty gas up here.
I always use Chevron supreme gas.
Even though I have a 420A and it doesn't really matter.
What ever you do just don't use Holiday gas! LOL
I used to only run shell gas but I switched to holiday when I moved back here, I drive too much to go out of my way to find a shell. I haven't had any problems with holiday gas.
Old thread sorry but I was searching and found this. So is it unsafe to go with high boost levels like 20-25 psi on 90 octane?
Just measure knock and once you starting getting knock back the boost off a little bit.
