Hahn vs. Howell who has better bottom end for 420a
99 gst 420a dsm
509
2
Jan 22, 2003
Turboville, New York
ok ima be doing the bottom end on my 420a very soon, whats the better priced company for a bottom end kit hahn or howell, and if hahn, which is more wise for around 300 horse @ 15-20 psi: 8.6:1 or 8.8:1 pistons... any coments are apresiated, but please no flaming
Use the 440's if you like, but use the SFMu not the FMU. If you get the SFMU you will be able to adjust idle pressure. That car won't idle those big INJ. on the stock regulator. You can go with either company for the bottom end I would buy the cheaper kit which I believe will bw howell.
well actually im not 100% on the cc of the turbo coupe injectors, they are 19psi i think
