[RESOLVED] AC drain hose location?
DSMGRUNGE
Sep 8, 2007
Lawtey, Florida
So I rescued my 95 rs from a rusty grave, and after body work, a paint job, and a new motor swap, I still have 1 more problem. Somewhere along the way I think the drain hose for the A/C came off. At first I thought it was a heater core but no tell-tell smell. Then I noticed no puddle after running the A/C in the florida heat. Now, where do I find this drain? Is it accessable from the engine bay or am I going to have to tear the dash out? I'm a mediocre mechanic on a good day. Thanks in advance for the help.
could not find it. Does anyone have a pic or an easy way to trace this thing down?
UPDATE: found where it goes through firewall inside, found the hole outside, but no hose was coming out. Tried to clean passage but it still leaks inside around rubber grommet. Tried to take the plastic shield off heater core and evap housing but couldn't get it out. May be a screw or clip I am missing. Does anyone know what size hose goes there? Was thinking if I push a hose through it would rather come out the hose then leak through the grommet
SOLVED: Pushed a piece of hose the same outside diameter as the inside of the drain through and it is working beautifully. No more swimming pool in my floorboard.Next stop...turbo install.
