16g
speed13a
Apr 13, 2005
Roy, Utah
Whats the max boost can i push with my 16G on stock injectors. i now drive a 95 eclipse GSX. im pushing 13-14 for daily driving. put its set to 13
I see that you just went and bolted on a 16 guage.wow another guy who thinks bigger is better.You need proper supporting mods to run a bigger turbo. Well, I hate to say I told you so buy youre going to end up back on here saying my car is making this really loud ticking noise what could it be? :nono: :toobad:
I ran 16psi on my 16g on my old car before i put on the t04b and supporting mods on ,with a stock catback exhaust and stock injectors. I did have a walbro 255 though. It ran good, No problems.
My friend has a ported b16g with stock injectors, No problems there either..
My other friend is running 18-19psi on a b16g ported/clipped with NO problems, On stock injectors..
If you have an exhaust and a fuel pump, You should be able to run 15-16psi, Every car is different though.
get a logger, end of story
octane plays a role too. IMO 15lbs is fine on cali 91 octane (assuming injectors are not clogged at all) and 16-17 may even be ok if you have 93-94 octane, but as said above the only way to know for sure on your own car is to log. 13lbs is almost always safe.
    • 92AWDHX40
    • eclipsemf
