safc 16g setting
96_AWDtalon
66
Nov 22, 2008
brookpark, Ohio
ok i have a 2g 5 speed with a e316g 560cc injectors and a afc 2 is there any setting for this set up never tuned anything before so i need some help
Thanks
Kevin
nathans right... i installed a SAFC II and 660cc injectors without a logger and getting the car to run correctly took awhile cause your basically going off of feel which isn't good because you really can't tell what your cars doing. heres what a buddy (far more knowledgable than me) and I used after installing my SAFC and injectors to tune, RRE has some good info on different setups. just pick whats closest to yours and BE CAREFUL if you don't have a logger/wideband.
RRE's Super AFC Setting and Adjustment Tips
Apexi Super AFC For The Eclipse/EVO
:dsm:
You'll definitely need a datalogger and I would highly recommend a wideband to dial it in. A good start would be -15- -20 for your low settings though.
Read the above posted articles as well as some others to get an understanding of how this product actually works by "hiding airflow".
But like mentioned, you're not going to get too far without at least a logger
I agree with everything said above. To get a base line I always had taken the stock inj
(450) and divied them by the new inj (your case 560) wich gives you .80xxxxx, then subtract by 1 and gives you how much to pull fuel to act like stock injectors to idle and cruise normaly.
