4G63T Valve spring Info
BogusSVO
5,886
336
Jul 1, 2009
Pensacola, Florida
just some quick info on stock replacement valve springs from SBI
Part Number #160-1280
Free length 1.910
O.D. 1.110
I.D. .754
Wire size .145x.178
Closed position
pressure & Length (intalled specs)
[email protected] Valve closed
Open position
Pressure & length Valve Open
[email protected]
solid height
1.100
The factory installed springs should be close to this also.
EDIT: I just checked 7 sets of used 4G63 valve springs, and only came up with 1 and a half sets of decent used springs.
Most springs checked between 45-55 Lbs @ 1.575
I would say a good spring should test at [email protected], Most spring manufactures, will allow 10% loss in spring tention for spring "break in"
I used a Rimac spring pressure tester.
Ferrea "beehive" Spring info
Specs on the springs
- Spring O.D. - 23.87mm / 28.07mm = .939/1.105
- Spring I.D. - 14.73mm / 18.85mm = .579/.742
- Seat Pressure - 90 lbs. @38mm = 1.496
- Open Pressure - 225 lbs. @28mm =1.102
- Rate Inch - 342 lbs.
- Coil Bind - 23mm =.905
- Max Net Lift – 13.5mm = .531
- Spring Material - PAC Alloy
http://www.extremepsi.com/store/customer/product.php?productid=21647&cat=1417&page=1
BC 1100 Valve spring info
Spring Pressure:
BC1100 Seat:
Colsed 1.500" @ 95 lbs /
Open: 1.000" @ 235 lbs /
Coil Bind: 0.935"
(no machine work required)
http://www.briancrower.com/makes/mitsubishi/4g63.shtml
GSC Power-Division 4G63T Beehive Single Spring Set
Spring Pressures :
Seat @ 1.56"=68 lbs / .300"=160lbs / .400"=190lbs / .450"=210lbs / .625"= Coil bind.
http://www.vr-speed.com/store/gsc-p...spring-set-1g-2g-dsm-evo-8-9-4g63-p-2046.html
Kiggley springs
97lb Seat Pressure at 1.440"
325lb/in Rate
http://www.shop.kigglyracing.com/product.sc?productId=2&categoryId=1
I will keep trying to add info as I find it.
Can I put delta k272 and rev upto 7000 rpm's with springs and retainers stock? or need upgrade springs and retainers.
Thanks
Sines those are the Delta clones of the Kelford Cams 272, you would need the same spring upgrade as the "name brand" Kelfords
Not to bring up the thread again, but weight has A LOT to do with valvetrain behavior. Valvetrain that weighs more will be affected more be inertia than valvetrain that weighs less. I run a good set of stock evo 8 springs with stainless valves, and I lost quite a bit of valvetrain weight. I lost 37 grams per valve/spring/retainer with stainless valves and evo springs.
    • eclipsemf
