Vacuum Delete Clarification
PFC_CiarlilloM
234
May 22, 2011
Euclid, Ohio
Okay, so, I am in the process of redoing my head gasket, and like a mad man I ripped the vacuum lines off of the back of the intake manifold without really looking at everything to see where each hose went. Now, I can't really follow the OEM diagram to connect each line correctly for some reason, but to my understanding those lines are for emissions, and aren't really needed.
I guess what better time to do the vacuum delete then now? Anyways, I just wanted to clarify/verify that I can pull EVERY vacuum line, and only run the vacuum lines in this picture that I attached.
Sorry to beat on a dead horse, but just wanted to be safe than sorry.
More info;
1996 (Auto) Eclipse GSX
Glowshift Digital Boost/ Oil Pressure Gauges
NXS MBC (Stainless Steel revision)
More info;
That picture is exactly what I have on mine.
Yeah what he said^ The solenoids don't have suction or anything. And the breather port for the gas tank is coming out of the firewall beneath where the battery would sit and is connecting into the charcoal canister. I think its gray, but I remember it has a little arrow on it. You can remove the canister (the flimsy bracket that holds it on can be bent to your liking to fit a rachet down there) and just leave the breather port there. Do not cap it off haha
what if you didnt want to delete emissions im running a gm maf with a 3" intake pipe off the turbo and now i dont know what to do with the line comng off the charcoal canister that used to run to the intake.. any suggestions?
yea im kind of confused on that, i bought a catch can and i understand one line goes from the ccv to the catch can but im not sure what the other line would go to if there's a diagram i havent been able to find it, but i see pictures of people with no intake pipes running catch cans and have no clue what theyre using for a vacuum source
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
