View Single Post
Old 05-17-2005, 12:27 PM   #3 (permalink)
BGizzlePatrick
Proven Member
Classifieds Rating: (0)
Reputation: BGizzlePatrick is an unknown
The soaked piece will look like this:
-PICTURE-
-PICTURE 2-
Depending on how much hardener you put into the mixture it will take a couple of minutes to couple of hours for the resin to dry and harden. I just left it out over night. The next day you can go get some Bondo Body Filler such as this one:
-PICTURE-
You can get this at HomeDepot and WalMart as well. Now, I have used this stuff first but found its kinda hard to work with because it get very "chunky" and uneven once it dries and u still try to put it on. So I stopped using this one and started using just the regular Fine Bodyfiller from Bondo i found it work sooo much easier.
-PICTURE-
I used that pink plastic spreader to put the bodyfiller on first but found its alot easier and more fun if you get yourself some latex gloves and just use your hands to put it on.
This is the piece after i got the first coat of filler on it and let it dry for some time:
-PICTURE-
I wanted to see what it will look like so i took the tweeter and held it in:
-PICTURE-
Note, I bought me a litle Dremel tool and it made everything soooo much easier. After the filler was completely dried i took the dremel and cut out all the plastic inside the piece to get the tweeter to go in.
This is the piece after i sanded the body filler down for the first time. Since the Fiberglass enforced body filler is soo hard i ended up using the dremel to get it to this point:
-PICTURE-
-PICTURE 2-
Since this was very very close the the form i wanted i just needed to even everything out and get it to look nice. So what i did is i took some crylon plastic paint primer and sprayed it on so that when i put another layer of body filler on it and sand it down i can tell when to i have sanded enough lol. Thats just me though i just thought that makes easier for me. This is what it looked like after the second sanding with 100, 120, and 220 grid sandpaper:
-PICTURE-
-PICTURE 2-
Offline
[posts] Reply With Quote
Sponsored Links
