twicks69
Supporting Vendor
- 4,335
- 2,075
- Mar 12, 2004
Milwaukee,
Wisconsin
I am in the process of accumulating the parts required to install another set of fuel pumps in my car and am looking for anyone that has pictures of a twin in-tank fuel pump setup on a 2G AWD.
I am curently maxxing out the twin fuel pump setup consisting of a Walbro 255HP in-tank running a AN-6 feed line off the stock hard line fitting, then running to a Walbro 255HP in-line fuel pump, then to a -6AN line to an in-line fuel filter to the fuel rail. The fuel rail is a 1G stock rail with FIC Bluemax 1350cc injectors and an AN-6 return line to the fuel pressure regulator and then to the stock return line.
The new setup is going to be a quad fuel pump setup consisting of two identical pump setups as listed above.
Dual in-tank Walbro 255HP's in parallel with each fuel pump running an AN-6 feed line to in-series Walbro 255HP's per fuel pump, then each fuel feed line will run to an independent fuel filter and then to both ends of a billet fuel rail machined for a center-mounted return line to the AFPR.
I will be running AN-6 bulkhead fittings on the pickup assembly for individual feed lines, and an AN-8 bulkhead fitting for my return line. The key problem I am facing is HOW I am going to fit both fuel pumps with bulkhead fittings on a 2G fuel pickup assembly? I know how to do all the wiring, and the rest of the plumbing is simple.
I already have all the pumps, fittings, etc. I just need to get some direction by people that have done twin in-tank fuel pump setups on a 2G with individual feed lines and a larger-than-stock return line so I can see some pictures of how they ran the pumps in the pickup assembly.
Ideas are welcome! Pics are even better!
Oh yeah, the Walbro 255HP in-tank to 255HP in-line with AN-6 feed to 1350cc injectors maxed out the pumps at 779AWHP, and the same pump setup on 1000cc injectors nearly maxed out the pumps at 766AWHP/713TQ on the old setup.
I am shooting for over 900AWHP, so this is the setup I am going with.
I don't know if anyone else has attempted to run quad fuel pumps in this orientation on a DSM before though. The only people I know running triple or quad fuel pumps are supra guys that have bolt-on options.
As well, the Full Blown twin-in-tank fuel pump assembly is ONLY an option IF it has individual AN-6 feed lines and an AN-8 return line. I do not want to run a Y-fitting or anything with only one feed line -- it must be two individual feed lines (parallel) to in-series fuel pumps.
Any help is greatly appreciated!
Also...I am on a time crunch....I have 8 days to create, fab, install, plumb, and wire up the quad fuel pumps for the next race. If it isn't done by the next race, then I am on my own schedule for doing it.
Thanks,
Thanks,
