VETTE_50_TH
Banned Member
- 3,732
- 23
- Jun 24, 2004
Columbus,
Ohio
Nice, thanks for the heads up!
James
James
I was able to confirm that the camaro ss brembos are also a bolt on part. Not sure what the piston diameter of these is however. This maybe the same caliper as the cts-v.
The GXP caliper also has the 130mm bolt spacing, however they accept a 12mm mounting bolt instead of our 14mm. Theoretically they could be drilled and tapped for 14mm very easily considering they are made from aluminum. The GXP calipers i believe also have the larger pistons found on the sti,evo,g35.
Can anyone get these part numbers or specs?
, my 98 Z28 has 2pot calipers. and 4th gen SS have the same brakes as Z28's
You guys comparing piston size forget that with hydraulic brakes that the piston area is automatically considered the pad area-not piston area itself.
Well, that settles that.
it would be pretty hard to believe that stock DSM 2pot calipers would be as good as CTS-V 4pot brembo calipers
i would think that the area of 14" rotors would be much better at resisting brake fade right?
I got the part numbers for the GXP and CTS-V 6-pots
cts-v brembo 6-pot
25912967
25912477
These should bolt on but I'm not sure if we can get rotors this large...
not sure what you mean here? piston area is piston area. pad area has nothing to do with clamping force. pad mu * clamp force * effective rotor diameter = brake torque. pad area plays no role whatsoever in that calculation.
hydraulic pressure acts on the pistons, not the pads. i'm guessing we're thinking the same thing, but wanted to be clear on it..
Actually, its rotor radius roughly at the pad center. Technically it should be the centroid of the pad /w respects to the center or rotation assuming the pad has even pressure at all points, but Pad center probably works
Try again, you've got complete knuckle/hub/rotor/caliper assm part numbers.
The 14 inch rotor described above from the 370z or g37 will work perfectly. Im not sure why people are battling this. Also cheaper than any other option at 100 a piece.
James
