This modification is designed to let your car's hood open all the way, intill the hood is vertical. At this position it is self supporting so no more support rod is needed for the hood. The hood itself rests with its lower edge on the bottom of the windshield. The weight of the hood keeps it at the open position. This allows for better room and light under the hood. The hood can support itself in low winds but should not be left open in high winds.
Time needed: 30 minutes
Tools needed:A 12mm wrench and something to cut with (angle grinder, dremel, saw)
Procedure:
1. Mark the hood hinges alignment with a sharpie on hood and body, it will help a lot later.
2. Start by taking off the hood, it is connected by four bolts.
3. Then take the hinges off which are held by one nut and one bolt each.
4. Now you can look at the hinge and see that there is a piece of raised metal (hinge tab) that blocks the rotating side of the hinge from moving any farther. The solution is to cut this piece of extending meta (hinge tab) on the rotating side to make it shorter and thus not hit the blocker on the base of the hinge assembly.
This picture shows the clearance of the extended metal (hinge tab) and the blocker on the base of the hinge.
The finished hinge.
5. To support the hood in high wind you can drill a hole through the hinge for the placement of a pin. I choose to drill out two holes for better support and slightly less movement.
The two holes for the placement of pins.
6. Replace the hinges and align them to the marks, then attach hood and align. Now you can remove the hood support rod or not.
These pictures show the hood being supported by the window, while not using the safety pins.
The window was already cracked before I bought the car.
If anyone has any questions or comments feel free to PM me at any time.
Please rate this post.
Procedure:
The finished hinge.
