View Single Post
Old 02-08-2008, 07:38 PM   #214 (permalink)
dsm-onster
DSM Wiseman
dsm-onster's Avatar
Region: Mid Atlantic
Classifieds Rating: (5)
Quote:
Originally Posted by ceedawg View Post
Well how do you come to that conclusion when HTT is saying the 6blade wheel is the actual upgrade?
The 6 blade IS an upgrade to the 8 blade hx40 and the hx35 compressors. The 7 blade is the super40 compressor. . .
Quote:
This sounds like the turbo you had encouraged me to sell,but with the bep hsing. Basically my HX40/35 hyb with the BEP HSING. What chgd your mind?
Discovering that the 8blade hx35 compressor and 8 blade hx40 compressor have identical designs except the hx40 has a 4mm larger inducer changed my mind. . . The little hx40 map confused me royal. The hx35 turbine with the .55 a/r housing is likely not enough for the hx40. The turbine is already out of the 10% diameter rule of thumb. And the bep housing is much smaller than the housings designed for the hx35 turbine.
____________________________
Matt
dd '90 GST, Holset H1C
Online
[posts] [gallery] [blogs] Reply With Quote
Sponsored Links
