thekellbeast
- 1,518
- 7
- Jun 28, 2003
Portland,
Maine
So it's time for me to get a new clutch, and I'm trying to decide between the Centerforce dual friction, and the Fidanza 4.3 (Four Point Three). I've heard some good things about the CFDF clutches, and some bad things. I've figured that some of the bad things are from improper installation/break-in methods. I haven't really heard much about the Fidanza clutches at all. The price is pretty comparable between the two.
I'm planning on getting OEM throwout bearing, clutch fork, pivot ball, etc. I'm going to run a Fidanza flywheel; it's allready here, not installed though.
This is the CFDF from SBR - $355
http://www.slowboyracing.com/estore/product.php?productid=1206&cat=106&page=1
And this is the Fidanza from UltraRev - $378
http://www.ultrarev.com/product.php?productid=34995
According to Jack of Jack's Transmissions, I apparently broke the clutch disk hub on my stock clutch (157k miles). I'm looking for a clutch that will be a decent daily driver, but will still stand up to a lot of abuse/onramps. I'm not a pansy, so I'm not going to bi*** about things being 'unstreetable,' as long as it's reasonable. So what are your experiences with these clutches, and what kind of power can I expect them to hold? Thanks.
Oh yeah, car has an 18g at stock boost, but I'm going to run 20+ with water/alcohol injection, daily.
I probably won't end up getting one, but the thought had crossed my mind - but only for the oversteer.
