The "infusion pot" is basically a funnel shaped assembly that allows you to thread the tape through a slot. You fill the thing with silicone. It coats the tape with silicone and strips off the excess as you pull it through. It doesn't work perfectly. I had to keep poking the silicone towards the bottom.
Another method that much simpler but doesn’t do quite as good a job distributing the silicone is to lay a 15 foot strip of tape on the floor and squeeze a tube of silicone down the entire length. At least two beads of silicone works best, rather than one thick one. Roll the tape tightly onto a spool and the silicone be squeezed into the tape. When you apply the tape, be sure to cover any bare spots with your messy fingers.
____________________________
Ron
