Activity Feed
Live updates
  • pauleyman replied to the thread 2G I think my crank timing is off?.
    · 55 1,782
    I'll elaborate further. You know what the shafts looks like It's a counterweight? The shaft is geared to oil pump sprocket. Each time you turn that sprocket all the way around the shaft spins 1/3 of a turn. So....Once in every 3 turns its in the...
  • eddyspaghetti replied to the thread 2G I think my crank timing is off?.
    · 55 1,782
    Ok, so all 5 marks are lined up, when I mean "fighting" I could spin it left or right if I really wanted to but it's a little bit stiff is what I mean, I haven't been able to put the screw driver in because I can find the plug to do so, I've been...
    · 55 1,782
    I don't think you understand. Each spin is a full rotation and lined up on the mark. The shaft is geared behind the pump. That's why its only in phase once every three rotations. You always check with the mark lined up. What do you mean fighting...
    · 55 1,782
    Well since I cant find the screw, I saw an Evo 8 video of how to identify if it's in the right position, the sprocket is fighting me to turn passed the left of its mark and passed the right of the mark, it doesn't fight me when I want to line it...
  • xn35 replied to the thread ECMlink Lowdoller Map sensors.
    · 18 598
    I just can't get the car to idle correctly. I have to adjust the PSI/volt way down. Its scale is very close to the aem 5bar. I have to set it at around 12psi/volt vs 18psi/volt which is what it should be at just to get a really rich idle. I was...
  • jesse12345 replied to the thread 98 Eclipse GS high school dream build.
    · 45 3,284
    The only thing I don't like about the 2.4 valve cover is the spark plug holes don't line up at all. It just bugs me for some reason.I'm not going to lie driving to school everyday with my bro in that exact car was so awesome. I loved that car...
    · 55 1,782
    Hello y'all, went ahead and set the timing belt tensioner counter clockwiseI'm having trouble finding the cylinder block plug to check the oil pump timing, it seems pretty tight in here behind the engine, doesn't seem like there's room for a...
  • victorgalant replied to the thread Venezuelan E33A.
    · 39 3,113
    I really don't know, back when I bought the car didn't pay attention to any of that, but I think is the one that came with the broken engine. this is a 1991 model, SNGML to be exact. mmm maybe I can check the part number for the CAS. anywho...
  • miliman13 replied to the thread ECMlink Lowdoller Map sensors.
    · 18 598
    So selecting a min and max for the straight line. Well if you don’t know, you can find your answer by doing the test they way I did. Use a tire gauge and use air to pressurize the sensor. Start with normal no pressure then record the voltage...
  • steve replied to the thread 2G I think my crank timing is off?.
    · 55 1,782
    I couldn't remember 100% so I looked it up to make sure what I thought I remembered was correct. I find myself doing that a lot more often as the years go by.
  • miliman13 replied to the thread Venezuelan E33A.
    · 39 3,113
    It’s def a green top 1G CAS.But the 89-90 version I believe has the wires coming out of the top of the sensor, Did you have another style sensor before ?
    · 18 598
    Sorry I should have been for clear. I'm having trouble with my user defined values. What I think should be used doesn't seem to work for min. And psi/volt.
    · 39 3,113
    Good news! the radiator shop said it was all good and got it home. Installed it and fitted perfectly, but decided to put it in the back for now since I have to take all the wiring out and fix it. Many wires were exposed, broken or badly fixed; so...
  • awdseegs replied to the thread ECMlink 1G ECMLink Log Review.
    · 16 540
    Thank you for pointing that out.
  • SixBolt_16G replied to the thread ECMlink 1G ECMLink Log Review.
    · 16 540
    You forgot to do this in your last log... and not sure if this is on purpose, but your fuel pump is set to always be on in the misc tab.
    · 18 598
    So I went into some detail here : You must be registered to see element.You must be registered to see element. This is a plot of actual recorded values VS advertised specs.For a cheap EBay 4 bar. Basically just proving the sensor works purdy...
  • miliman13 replied to the thread 98 Eclipse GS high school dream build.
    · 45 3,284
    If you had this in high school, then I was the guy who once got a ride home 🏡 from school 🏫 in a GS and instantly fell in love with the 2G. It was this same red and had nearly identical wheels.It was my first time seeing an eclipse in person...
    · 45 3,284
    I decided to just say screw it and throw some power steering in. I loved the room in the engine bay but I have to make this thing how I would of in my younger years. I can honestly say I don't think I'd ever get rid of it unless I'm going for...
  • Syclone#334 posted a reply to a question on the classified ad Wanted Wanted 90-91 Plymouth laser wheels.
    No interest in shipping?
    · 18 598
    You must be registered to see element.I have a 4 bar and 5 bar. I cant seem to scale either correctly
