windshield washer fluid
DOHCSIDE BOOST
99
Feb 2, 2004
mcallen, Texas
where do i fill it up all i see is the one for the back in the trunk, or does that one circulate to the front?
Well then you must have either a blockage or a leak somewhere. Keep the lever engaged for a few secs-- sometimes (especially if the entire line was empty) it can take a moment for the fluid to make its way all the way up to the front. Can you hear the washer fluid motor running when you engage the washer?
yeah i hear it, i left it held for about 1 minute, and nothing, i dont see any leaks either, stupid idea maybe but wpuld drano or something unclog it?
I suppose it could, but I would be hesitant to use something like that on a rubber line. I don't know, but it might eat through it. I know household plumbing is PVC which is similar, so it might be safe, but I'm just not sure.
What's more likely is the washer nozzle itself is clogged. Those things are pretty tiny. Take a needle and stick it into the little hole in the end of the nozzle to try and clear any blockage.
GAAH! Do you want Drano all over your paint?
Pull out the spare, get some vacuum hose and siphon out all the washer fluid you can, and once the resevoir's empty, _carefully_ (without breaking the nipple on the pump) pull the hose off. Go to the hood, again carefully pull off the hose, and run some air through the hose and blow out the dead bugs. Then take some fine wire (staples are the right size) and clean the wax buildup out of the nozzles on the hood. DO NOT REPLACE THE NOZZLES WITH LED LIGHTS. Blow some air through that piping, too. Put the hose back on the pump in the trunk, put a bottle on the end of the hose in the front, and run until the crud's flushed out. Hook it back up to the nozzles and see if it's working. Replace the 87¢ washer fluid with some $3 Rain-X washer fluid.
i filled it but nothing sprays out in the front, so i just bought 87cent of washer fluid for nothing
Haha, you thought you were cheap... I use water... :( But I had my car for a long time and have yet to tested to even see if my sprayers work.... Wonder why the reservoir keeps getting low...:confused:
LOL... follow that "warning label"
:thumb: attach an air compressor hose to one end the tubing system and blast that crap out. Thats how i fixxed mine! Hopefully its not a bad pump.
haha, my paint is all jacked up dude so i dont care what happens to it. plus cars getting painted maybe in about 2 months. i just got that 87 cent wahser fluid cause i saw it walking out of a store, i didnt see any rain-x, but ill look. the pump and motor work cause it sprays out the back washed, and hell no im not buying any led washer light things, thats ###. leave that stuff for brian spilner, anyways poked them with staples and nothing, gona try the air compressor idea see if bugs and crap come out. who knows what ill find.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
