oil leak passanger side
tlikethedrink
361
92
Sep 11, 2007
ABQ, New Mexico
I just got back from out of town. I noticed i got a huge oil leak. Like 1/2 quart was dripped on the floor. It looks like its coming from the passanger side. I havnt done anything to that side of the engine. I checked the CAS as once it was left loose and leaked something fierce. I was hoping this was what it was again for a quick fix. No dice.
Im going to jack up the car in the morning. any points i should look for? known problem areas?
I might take out the battery so i can get a better look under the intake mani. My head is freshly rebuilt about 10-15k so the engine bay is clean and gaskets are new. A problem should be easy to spot.
Do you know if its leaking from the top or the bottom?
i have no idea where its leaking from. all i know is its alot. especially it leaking that much when the engine isnt running. who knows how much it leaks running. ill start it and look for any gushing.
front or rear of the motor?
im gonna have to say the rear. thats my best guess and is also why im goin to pull the battery to take a peak back there. i figure with that much leaking, the problem should be obvious.
Has anything been done to the engine in reacent history. Like a timeing belt change? If so check the bolt that has to be removed to index the rear ballance shaft. If that was left loose and backed out Well you get the picture.
Man if that is it that would be an easy fix.:thumb:
axel seal it is. i put in some ATF. it was red. as soon as i put it in i looked back under the car and saw a few red drips. i see where its coming from now. the boot is torn too. so my next questions are...
how much would this cost to get it fixed?
how much for the parts? what would i need? could i do it myself or is it rocket science?
-ive change out CV axles before. just not familiar with the seals....
does anyone have a write up?
If you have taken the axles out before, you just go a step further and take the seal out with a pointy sharp tool, then lube the seal with some oil and gently press it back in. As for the cost, if you do it yourself, I *think* I paid about $30 for both the driver and passenger seals from the dealership.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
