idle and start problems
Hilter9053
Jun 21, 2009
Bellingham, Washington
ok so pretty much my car has had starting problems since I bought it and it is only getting worse. Last time I started it it took like 10-15 tries to get it started and when it finally starts it dies at first. Also I don't know what normal idle is but mine is around 500 at first and around 650-700 when it is warmed up. when it is not warmed up if you give it any throttle at all it dies. It has to sit for 5-10 min just to warm up and after that there is no problems. I tried using the trouble codes but since my cars computer is apparently retarded it doesn't work and it just gives us random long and short lights. Any help at all would be welcome.:thumb:
did you get this problem fixed yet? i had a gsx that did the same thing but more so in the fall and winter. check the sensors by your thermostat. there is one with a single pin and one with two pins in a T form make sure the wires are hooked up. a lot of times they get brittle and break off. plus look at the other sensors right there too. it could be that vacuum line sensor is cracked...
Just my 2 cents....
no unfortunately its not fixed yet. we messed with the throttle cable and it helped with the start but it is still running really rough at first.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
