All these gauges are in great condition. Used and sold as-is but I do guantee they are functional.
Apex-I EL Series Water Temp gauge, used - $75 + shipping
- Has a blue backlight, warning light feature, and peak/hold capability. Perfectly working, was used in my car race car until I moved to a completely digital dash. Including a little surface mount dash cup you can use.
Apex-I EL Series EGT Gauge, used - $75 + shipping
VDO Oil Temp 120-300 deg F gauge only - $25 + shipping
- Perfectly working order but does not include the sensor (usually around $30, I can research and find you to the right one). Includes a small faux carbon fiber cup used to mount on a surface.
VOD Oil Pressure 0-100 psi gauge only - $25 + shipping
- Perfectly working order but does not include the sensor. Includes a small faux carbon fiber cup used to mount on a surface. Sensor I used is VDO 360086, I think around $45 but you need to get adapters plus a line extension. Make sure to mount it onto the chassis with a rubber hose clamp with a line extension and not directly to the engine (to reduce vibration) otherwise it will fail prematurely.
These two are wired together like they were in my race car, but easy to separate.
Here is how I had them in my racecar:
I also have a grey Triple 60mm a-pillar gauge mount in perfect condition. I can dig it out and send pics if someone is interested. $25 + shipping.
