is red 1997 talon tsi awd turbo charge 7 bolt engine with about 113xxx original miles the car has definitely been mess with like all this cars, has some surface rust in some spots nothing concerning the only parts concerning are the driver and passenger rear quarters i have the owners manual but someway along the way it got wet still usable
i try to put as many pictures as i can
the car has the following good stuff into it
the car will come with an extra engine alone with a bunch oem and spare parts
it will also come with a stroker kit forged crankshaft along with wiseco pistons and rods
6266 precision turbo with fatboy exhaust manifold into a 2.5 straight pipe into a borla muffler
44mm after market wastegate
big no name after market intercooler no name blow off
big 1600cc injectors from injectors clinic
innovative fuel easy adjustable fuel pressure regulator e85 compatible with -8 ptfe line
fuel pump is a walbro gss352 600hp+ capable
platinum racing wires with oem coils
gates blue timing belt low miles on it
new waterpump
new alternator
new oil pump
innovative wideband
dsm link v3
6 inch screen with apple play
big boat battery in the trunk
fuse center where the airbag used to be
has good snow tires all around
the rotors and brakes are new all around with brake fluid flush and change
rear diff has new redline oil in it fluid came out pretty good
has upgrade speakers
for the bad now
engine runs and drives but the no name waste gate has a big exhaust leak so car has a hard time idling
the wire harness has been mess with
no ac components on the car (have some parts for it)
no abs components on the car (i have everything for it but the abs module)
valve cover gasket leaks
fuse box has seen better days
the drive belts could be change \
motor mounts could be change
front driver side caliper could use a rebuilt
the only concerning rust I see is in the rear quarters more so on the passenger side
it has a black metallic wrap is a 10ft wrap meaning it looks good from 10 ft away
the car is locate in Norwalk CT 06851
let me know if interested and we can get on the phone to talk more about the car and if you have any more question i also have a video running if interested
you guys would be the experts on this car so im asking for a reasonable offer nothing crazy high or a steal something that is a good deal for someone that is buying it thank you
new waterpump
new alternator
new oil pump
innovative wideband
dsm link v3
for the bad now
