Wanted 2g 97-99 2GB MANUAL Transfer Case
Closed
Need transfer case
Status
This ad has been closed. Reason: Received the part I was looking for 👍🏻
If youre ever in a jam again you can change the final drive in the trans and run a 90 to 96 ratio tcase. I can't think of a reason for mitsu to have changed it but here we are.
One member found this helpful.
  • Like
Reactions: PheonixDSM
PheonixDSM
Thanks for the tip pauley, yeah I will definitely keep that in mind in the future. I just have a good working 2gb trans id really like to use,I’d hate for it to go to waste which is why I need this transfer case.Luckily Turbobird97 scouted a good find for me, I was able to contact the seller and purchase the transfer case. Thank you guys for your help and input 👍🏻
pauleyman
pauleyman
Keep the 2gb trans. I just meant if you find a front diff ring gear and drive gear from any 90 to 96 trans then you could use a 90 to 96 tcase. 90 would require a 22 spline output. My point was to use your existing trans a new tcase isn't the only option.
I saw one on eBay
  • Like
Turbobird97
Turbobird97
Duties are excessive from Canada for sure. Prohibitively so still on car parts.
Sorry to hear.
Turbobird97
PheonixDSM
Thank you so much man. I’ve looked all over and asked In all the groups I’m in, and even Ricky Nichols doesn’t have any 2GBs on hand. I looked all over EBay and only found 2GA’s and 2GB autos 😅 I’m messaging the guy now I will update if I purchase it. Until I do I will keep this post up just in case.
