pur97tsifwd
- 331
- 2
- Jan 31, 2006
Nevada,
Missouri
I have had the 93 talon for 5 years and since i have gotten it my dimmer switch has never worked when i turn the light on or driving lights the interior light are always on bright and i cant not adjust them how would i test my dimmer switch or wiring to find the problem.
Also i have been working on making my car a two seater by taking the hatch and back seats out to install sound deadening material and put some fabric down. I had to remove something for my abs that is below the seats over by the rear speaker which i did i extended the wiring harness and mounted it but now my abs light is on how can i test the device and wiring to check if it is working or getting power. I also have dsmlink v3 and the cable always in the data port will this cause my abs light to always be on?
