2gmitsueclipse
DSM Wiseman
- 2,404
- 798
- Jul 13, 2005
Auburn Hills,
Michigan
I have recently replaced a throttle body due to failed shaft seals. I took care when replacing the sensors to make sure they were installed properly. The car is a 98 GSX. I used DSMLink to log the TPS voltage with the car in the "ON" position carefully monitoring my adjustment to achieve .63 volts when the throttle plate is closed. When The car is started and idling, TPS voltage goes to .65-.67 volts. After a short drive and letting the car idle, TPS voltage reads .69 volts. I was trying to avoid using the TPS adjustment tool in DSMLink, but may resort to that. Once I get this taken care of, I can then focus on proper adjustment of the ISC. Have others had this problem before?
