2G Rear toe arm bolt
Yamahaulin
695
12
Jan 30, 2010
Bowling Green, Kentucky
Anyone know the length of the rear toe arm bolt on a 2g awd. Mine is seized and will have to be cut out.
You need to use the original one, because it has the eccentric configuration. Get it from any dealer, or JNZtuning.com, or STM
I don't need the eccentric I bought a set of Paul's adjustable arms.
So do I, but I would think that it's still safer to use the eccentric bolt (just my opinion) because there would be nothing to keep the bolt head from shifting. I would at least use a large washer that has the same OD as the OD of the eccentric. I unfortunately don't have a spare to measure. Good luck.
I did this on sat! its an m12 bolt, use 2mm washers on either side to make it touch against the outer plate so there equal left and right, the FSM says its 110mm but when I installed mine I could have taken 10mm maybe 15mm off so if you order the 100mm bolt it will be fine! I bought socket capped bolts as there 12.9 grade and are plenty strong enough!
See how its way to long! I bought all new 12.9 socket cap bolts and used the FSM for lengths! I found there actually quite incorrect! Im going to re do them by measuring the old ones and buying new bolts at the correct length! You could get away with a 90mm bolt but its a bit close to the end so a 95 or 100 would be fine. If in doubt measure yours.
