Palm iiic datalogger
highvan
85
Jun 7, 2006
Warren, Pennsylvania
My datalogger just came in a few days ago with all the software and cables that i need. I tested it out and worked great, but i have no idea what each thing is that it's showing me numbers for LOL Or whats numbers are good or bad? Any help would be great.
Do you know how to post a log onto here so we can look at it? It would be a lot easier to show you if you did. Let me go steal somebody else's log real quick.
Also, ever since i hooked up my the wire to plug it in, the ABS light stays on, is that normal? Can you also change settings on the car with a logger? Sorry, i'm very new to this
Yes, the datalogger also puts the ABS computer into diagnostic mode. The works around is to clip the wire to the ABS computer and put a switch in it is case you ever need to scan it.
There are no setting that you can change on a stock ECU. You can turn on and off the solenoids and injectors to testing but that's it.
Read these two links for what the logger is telling you.
http://www.technomotive.com/prod/datalog/datalogger.htm
http://www.hywell.org/plhelp/
Steve
