Resolved OEM Part Number
syrushcw
296
Dec 12, 2006
Trumbull, Connecticut
Well I need a couple parts that I am unable to find searching and my manual doesn't contain part numbers.
First the 4 bolts & nuts from drive shaft to rear diff ( I've seen threads for 3 bolts, contact JNZ and Look at this schematic "lets assume I'm an idiot" I contacted JNZ over a week ago nothing)
Second Rear Hard Brake line ( From pro valve to rear wheel well) I don't want to make new ones (don't have the tools) my stock ones are severed. After market prebent ones will also work.
Any help is much appreciated Thanks
Bolt - MB000938
Washer - MF450405
Nut - MF450405
ABS or non-ABS? And which brake line are you looking for? It runs from the prop valve to which rear wheel?
I love you for the first 3
I was told the rear doesn't matter since all the abs removal threads for 2g say you need to change only front and not rear. So I guess I'll say non ABS hard lines
Bolt - MB000938
Washer - MF450405
Nut - MF450405
Posted same number there for the washer and nut haha.
Is there any difference between these bolts and any other bolt used in the rest of the car? I need them too but I was just going to use spares I have laying around...
I guess I'm still confused on what line you're looking for. For a non-ABS system, I believe you have 4 brake lines that run from each wheel well to a port on the prop valve. From what it sounds like, you need one that runs from the prop valve to a specific wheel, no?
Oops, good catch. Sometimes copy/paste doesn't work on this computer, especially with CAPS. I fixed it in my original post.
I'm not sure on difference in that bolt vs. others. All the information I see is it's an 8x1.25x25 bolt - nothing else is mentioned.
I keep seeing everyone using CAPS, I have no clue where to find it though. Any info, it'll make life much easier I think haha. Sorry not trying to go OT! Thanks for the part numbers btw.
Woops sorry prop valve to rear passenger and rear driver wheel
Well Mitsu dosn't make 2 items I'm looking for anymore
MB895889 Brake Main RH Tube
MB895894 prop valve to the right wheel
I looked up the same part numbers for Chrylser and the discription is the same but like a $50 diffrence compared to Mitsu. Does anyone know if those are the right numbers for the other DSM manufactures?
Thanks!
Anyone?
