Mike431635
- 33
- 1
- Aug 31, 2003
Tampa,
Florida
I'm getting a downpipe from a 2gnt member soon and also a gutted high-flow cat. I don't want to get a CEL for a missing/inoperative cat so I'm thinking about doing something a lot of the 1.8T VW guys have been doing for years. It involves using spark plug non-foulers to space the O2 sensor out of the exhaust path and prevent the CEL.
Searched and searched all over the net, found some very interesting stuff, but most of it pertained to "tuning" the amount of oxygen the sensor sees, causing the ECU to recognize a "rich" condition and lean out the mixture and boost fuel economy. That's not what I want, obviously, but I understand a stock ECU makes the car run a bit richer than needed as a safeguard so it SHOULD be ok.
The car in question has been getting terrible gas mileage-- 13-15mpg, so I just replaced both the front & rear sensors a couple weeks ago. Mileage has gotten a lot better, hitting 20-22 in the city which I consider pretty good. I don't want to lose this and revert back to the terrible mileage I was seeing before just to avoid a CEL. Does anyone here know what the effect is on gas mileage by using a spacer like this to avoid a CEL? Theoretically, using some kind of O2 simulator does the same exact thing only with an voltage signal, so I'm interested in knowing the effect of such devices on mileage as well.
