CtrlAltDestroy
- 40
- 0
- Nov 27, 2010
Lemont,
Illinois
I have a 99 Eclipse GST Spyder, all stock, automatic.
This started last week. I was doing errands to multiple places. I came back to my car from the bank and it wouldn't start. The interior lights, radio, headlights, etc would come on just fine but when I turned the key it didn't try to start.
The interior lights would dim a little but the engine didn't try to crank. I tried to get a jump start but it didn't help. There were also some dash lights on. The battery and e-brake lights I definitely remember. The oil light and "service engine soon" lights I think may have been on as well. If I pulled the e-brake the light got brighter. When I released the e-brake it stayed on, but a little dimmer. I tried starting it in both neutral and park but neither worked.
Because of my situation at the time I got a ride home and went back to my car 3ish hours later. It started up just fine. I drove it home and it started fine after that. Jump to yesterday.
I was running errands again. I went for what would be the 3rd start withing half an hour and the same thing happened. This time I payed more attention. E-brake, battery, oil, and "service engine soon" lights were all on. The electronics all seemed to work fine but the engine wouldn't crank. I could hear a click-like sound that sounds like a relay switching coming from the middle of the dash (starter relay, yes?) and what sounds like the fuel pump trying to pump. I tried both neutral and park. The interior lights dimmed but no crank.
I walked home and decided to wait a few hours and try to start it again. I waited 3 hours and walked back to it. No luck, same symptoms. I was able to get ahold of my sister and tried to jump my car but it didn't help. I called a tow truck and had it towed home. There was some blue corrosion at the base of the positive battery terminal but it was tight around the post. I checked the voltage with my Fluke and it showed 12.61 volts.
This morning before work (about 12 hours after this started) I figured I'd try it one more time. I turned the key and it weakly cranked and fired up. I drove it the 20 miles to work. While it was running the lights that were previously on turned off right away. Once it fired up, no more battery, oil, ebrake, and CES lights.
8.5 hours and a work shift later I took off the positive battery cable. The contact point to the terminal was clean. I wire brushed the blue corrosion off anyway and cleaned the contact surface just to be sure. The car fired up with no problem and I drove home without incident.
I would suspect a bad starter or a problem with the starter wires but I don't see how that would fit in with the car starting up after it sits for a few hours. I have the same thoughts about the solenoid and ignition switch. If it's a bad battery I don't see how the electronics/lights would still work fine and how it wouldn't start with a jump, something I've done several times in the past (to other vehicles). The alternator going bad shouldn't prevent a jump start, right? And the battery was sitting at 12+ volts anyway.
Looking a bit online tells me that it may be a problem with the alternator. I guess I don't understand why it could be my alternator given the battery voltage and no-go from jump starts.
Tomorrow when it's light outside, and the weekend, I can jack up the car and have ample time to tinker. Any ideas?
Thanks for reading all that.
But yeah, good job
