1G No spark After Coil Pack replacement
zachsEVO3
169
Apr 1, 2008
Ithaca, New York
I have hit a wall with my 1gb GSX to the point where I'm considering selling it.
It was determined I had a bad coil (running on 3 cylinders) after discovering cylinder 1 had a super weak spark so I bought a new one off rockauto. Initially when I installed it, it seemingly started up on all four cylinders. Then I went to dinner, tried to start it up again and it sputtered and died at every attempt and now its as if I'm not getting any spark at all.
I have no idea what connection could have been tweaked I tried spraying its one triangular plug and the control module plug beneath it with crc electrical cleane.
THe starter still turns it over but no spark anywhere now. Is the connection just bad now you think? Has the ignition control module or that conncetion decided to take a dump you think? Thats the only other plug i disconnected to make installation easier, but again it started fine the first time....and only the first time.
Also if you have any suggestions as to how I should attempt to sell this car I'm all ears ha.
Any help would be much appreciated.
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
