1G (Need help)PTE 880 cc sport compact lower seals
Slobonator4G63
155
6
Jan 10, 2009
Winnipeg, MB, Canada
So I have gone threw the threads and the old forums and I did come across a post pertaining to what I was asking and with it being an older thread didn't imagine id get much of a response. So here I go, I have a set of PTE 880 sport compact injectors that I wanted to use. I read on this forum http://www.dsmtuners.com/threads/pte-injector-with-lip.482015/ that FIC would work well with this application how ever I am about to order them of FIC and there descriptions of the way they describe the product seem miss leading. I have tried contacting them on Thursday with no luck and I really just want to get these lower seals. I just don't want to wait 5 business day only to find out they will not work. There going into my 1991 4g63t, I have tried to source the insulators locally and have had no luck with a generic lower insulator. Has anyone used the honda style PTE 880cc injectors with the FIC lower seal kit? I want them to sit on the next step like the FIC injectors do in this picture http://www.ffwdconnection.com/media...1e35df139433887a97daa66f/i/n/injectornew2.jpg I was told by a guy named TOM at FIC that the
Seal kit for Fuel Injector Clinic low-z injectors for DSM/Evo (NOT for scribed part numbers ending in "K")
were the right seal for me but looking at the post that the seals were off a 1650cc bluemax ? does anyone know if the lower seals are the same in both the SLK 125/6x4 and the SLK 126 x 4-K? Any input would be awesome here I have been racking my brain for a day or two weather to order both and take the hit on one. But I would like to get it right the first time rather then hanging onto a seal kit I would never need.
Any suggestion or answers would be greatly
appreciated
You can see the sets here. That was my old thread. I did more research and they're both just rebranded rochester injectors with a different spray pattern.
http://www.extremepsi.com/store/product.php?productid=17787&cat=0&page=1
I actually ordered the "pte kit" first but they are just stock seal size. You also need the blue spacer/sheet at the top injector aswell
So that link you posted of the seal kit if I seleted fIC as the seal kit I wanted will fit my PTE 880's? If that works great my only really question is for future when lets say exteme doesn't have stock and I wanted to order from Fuel injector clinic so will the http://fuelinjectorclinic.com/more-products/seal-kits/SLK-125-6-4 work as well I'm just trying to make this clear for anyone else hunting around for more answer to similar cc injectors
I honestly don't know the part numbers, most sites list just them fic dsm/evo injector seals. It depends if they have the flared end. I did some digging and pte machined and installed a pintle cap while fic just used a different set of seals but pte also had the un-machined style or sport compact for other applications. So you can either grind the lip to fit the pte seals like some people do or use the fic seal method.
http://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/484776-pte-1200-fitment.html
