Injector and Fuel Pump Supported Airflow
Alright, I've decided to spend some time at work and crunch some numbers on the most commonly used injector and fuel pump sizes. The list below will provide you with the maximum amount of air that a give fuel system component can handle. There are some assumptions that I had to make for the calculation to function. Such as:
1) Everyone is running 93 octane fuel @ a base pressure of 43psi.
2) The Denso stock replacement fuel pump supplys the same flow, at a give pressure, as the stock Mitsubishi pump.
3) Everyone's fuel pump and injectors are working at peak performance.
4) Target AFR is 11:1
5) I can't have everyone's injectors flow tested, so we have to assume that if you bought 550cc injectors, that they flow 550cc/min.
On to the numbers
Injectors
390cc @ 100% IDC will support 27.99lbs/min
390cc @ 80% IDC will support 22.39lbs/min
450cc @ 100% IDC will support 32.30lbs/min
450cc @ 80% IDC will support 25.84lbs/min
550cc @ 100% IDC will support 39.48lbs/min
550cc @ 80% IDC will support 31.58lbs/min
580cc @ 100% IDC will support 41.63lbs/min
580cc @ 80% IDC will support 33.31lbs/min
650cc @ 100% IDC will support 46.66lbs/min
650cc @ 80% IDC will support 37.32lbs/min
660cc @ 100% IDC will support 47.37lbs/min
660cc @ 80% IDC will support 37.90lbs/min
720cc @ 100% IDC will support 51.68lbs/min
720cc @ 80% IDC will support 41.34lbs/min
750cc @ 100% IDC will support 53.83lbs/min
750cc @ 80% IDC will support 43.07lbs/min
780cc @ 100% IDC will support 55.99lbs/min
780cc @ 80% IDC will support 44.79lbs/min
850cc @ 100% IDC will support 61.01lbs/min
850cc @ 80% IDC will support 48.80lbs/min
880cc @ 100% IDC will support 63.17lbs/min
880cc @ 80% IDC will support 50.53lbs/min
950cc @ 100% IDC will support 68.19lbs/min
950cc @ 80% IDC will support 54.55lbs/min
1000cc @ 100% IDC will support 71.78lbs/min
1000cc @ 80% IDC will support 57.42lbs/min
1150cc @ 100% IDC will support 82.54lbs/min
1150cc @ 80% IDC will support 66.04lbs/min
1600cc @ 100% IDC will support 114.85lbs/min
1600cc @ 80% IDC will support 91.88lbs/min
Fuel pumps
Numbers will be arranged in the following format:
"X psi = Y lbs/min"
where X = Boost and Y = Max airflow supported by pump
Stock 2g pump
10psi = 33.29lbs/min
11psi = 32.61lbs/min
12psi = 31.90lbs/min
13psi = 31.17lbs/min
14psi = 30.41lbs/min
15psi = 29.63lbs/min
16psi = 28.84lbs/min
17psi = 28.01lbs/min
18psi = 27.16lbs/min
19psi = 26.28lbs/min
20psi = 25.38lbs/min
21psi = 24.46lbs/min
22psi = 23.51lbs/min
23psi = 22.54lbs/min
24psi = 21.54lbs/min
25psi = 20.52lbs/min
Stock 2g pump (Rewired)
10psi = 42.08lbs/min
11psi = 41.51lbs/min
12psi = 40.92lbs/min
13psi = 40.30lbs/min
14psi = 39.67lbs/min
15psi = 39.00lbs/min
16psi = 38.32lbs/min
17psi = 37.61lbs/min
18psi = 36.88lbs/min
19psi = 36.13lbs/min
20psi = 35.35lbs/min
21psi = 34.55lbs/min
22psi = 33.72lbs/min
23psi = 32.88lbs/min
24psi = 32.01lbs/min
25psi = 31.11lbs/min
Walboro 190lph
10psi = 46.48lbs/min
11psi = 45.89lbs/min
12psi = 45.26lbs/min
13psi = 44.58lbs/min
14psi = 43.86lbs/min
15psi = 43.09lbs/min
16psi = 42.28lbs/min
17psi = 41.43lbs/min
18psi = 40.54lbs/min
19psi = 39.60lbs/min
20psi = 38.62lbs/min
21psi = 37.60lbs/min
22psi = 36.53lbs/min
23psi = 35.42lbs/min
24psi = 34.26lbs/min
25psi = 33.06lbs/min
Walboro 190lph (Rewired)
10psi = 60.68lbs/min
11psi = 59.85lbs/min
12psi = 59.01lbs/min
13psi = 58.16lbs/min
14psi = 57.29lbs/min
15psi = 56.40lbs/min
16psi = 55.49lbs/min
17psi = 54.57lbs/min
18psi = 53.63lbs/min
19psi = 52.67lbs/min
20psi = 51.70lbs/min
21psi = 50.71lbs/min
22psi = 49.71lbs/min
23psi = 48.68lbs/min
24psi = 47.64lbs/min
25psi = 46.58lbs/min
Walboro 255lph
10psi = 63.53lbs/min
11psi = 62.88lbs/min
12psi = 62.20lbs/min
13psi = 61.48lbs/min
14psi = 60.72lbs/min
15psi = 59.93lbs/min
16psi = 59.10lbs/min
17psi = 58.23lbs/min
18psi = 57.33lbs/min
19psi = 56.39lbs/min
20psi = 55.41lbs/min
21psi = 54.39lbs/min
22psi = 53.34lbs/min
23psi = 52.26lbs/min
24psi = 51.13lbs/min
25psi = 49.97lbs/min
Walboro 255lph (Rewired)
10psi = 72.15lbs/min
11psi = 71.47lbs/min
12psi = 70.77lbs/min
13psi = 70.04lbs/min
14psi = 69.29lbs/min
15psi = 68.52lbs/min
16psi = 67.73lbs/min
17psi = 66.92lbs/min
18psi = 66.08lbs/min
19psi = 65.22lbs/min
20psi = 64.34lbs/min
21psi = 63.43lbs/min
22psi = 62.50lbs/min
23psi = 61.55lbs/min
24psi = 60.58lbs/min
25psi = 59.58lbs/min
Walboro 255lph HP
10psi = 64.64lbs/min
11psi = 64.19lbs/min
12psi = 63.74lbs/min
13psi = 63.30lbs/min
14psi = 62.86lbs/min
15psi = 62.42lbs/min
16psi = 61.99lbs/min
17psi = 61.56lbs/min
18psi = 61.13lbs/min
19psi = 60.71lbs/min
20psi = 60.29lbs/min
21psi = 59.87lbs/min
22psi = 59.46lbs/min
23psi = 59.05lbs/min
24psi = 58.64lbs/min
25psi = 58.24lbs/min
Walboro 255lph HP (Rewired)
10psi = 74.29lbs/min
11psi = 73.86lbs/min
12psi = 73.43lbs/min
13psi = 73.01lbs/min
14psi = 72.58lbs/min
15psi = 72.15lbs/min
16psi = 71.72lbs/min
17psi = 71.28lbs/min
18psi = 70.85lbs/min
19psi = 70.42lbs/min
20psi = 69.99lbs/min
21psi = 69.55lbs/min
22psi = 69.12lbs/min
23psi = 68.68lbs/min
24psi = 68.24lbs/min
25psi = 67.80lbs/min
Denso US EVO 8 Stock Pump
10psi = 39.96lbs/min
11psi = 39.10lbs/min
12psi = 38.12lbs/min
13psi = 37.31lbs/min
14psi = 36.39lbs/min
15psi = 35.45lbs/min
16psi = 34.48lbs/min
17psi = 33.49lbs/min
18psi = 32.49lbs/min
19psi = 31.47lbs/min
20psi = 31.47lbs/min
21psi = 29.35lbs/min
22psi = 28.26lbs/min
23psi = 27.15lbs/min
24psi = 26.02lbs/min
25psi = 24.87lbs/min
Denso EVO 8 Stock Pump (Rewired)
10psi = 51.23lbs/min
11psi = 50.36lbs/min
12psi = 49.48lbs/min
13psi = 48.60lbs/min
14psi = 47.72lbs/min
15psi = 46.85lbs/min
16psi = 45.97lbs/min
17psi = 45.09lbs/min
18psi = 44.20lbs/min
19psi = 43.32lbs/min
20psi = 43.32lbs/min
21psi = 41.55lbs/min
22psi = 40.67lbs/min
23psi = 39.78lbs/min
24psi = 38.90lbs/min
25psi = 38.01lbs/min
Denso Supra 260
10psi = 70.70lbs/min
11psi = 70.06lbs/min
12psi = 69.42lbs/min
13psi = 68.77lbs/min
14psi = 68.12lbs/min
15psi = 67.45lbs/min
16psi = 66.78lbs/min
17psi = 66.10lbs/min
18psi = 65.42lbs/min
19psi = 64.73lbs/min
20psi = 64.03lbs/min
21psi = 63.32lbs/min
22psi = 62.60lbs/min
23psi = 61.88lbs/min
24psi = 61.15lbs/min
25psi = 60.41lbs/min
Denso Supra 260 (Rewired)
10psi = 82.91lbs/min
11psi = 82.38lbs/min
12psi = 81.83lbs/min
13psi = 81.28lbs/min
14psi = 80.73lbs/min
15psi = 80.17lbs/min
16psi = 79.60lbs/min
17psi = 79.03lbs/min
18psi = 78.46lbs/min
19psi = 77.88lbs/min
20psi = 77.08lbs/min
21psi = 76.71lbs/min
22psi = 76.11lbs/min
23psi = 75.51lbs/min
24psi = 74.91lbs/min
25psi = 74.30lbs/min
Although these are the maximum values that the fuel system components can support, I do not advocate running the fuel pumps at their maximum flow. I also don't recommend running your injectors above 80% IDC. Why, you might ask.....
Lets say you are running on the 190lph Walboro @ 20psi and are flowing about 37lbs/min of air. At that point you are within the tolerance of a perfectly functioning pump. For some reason your voltage drops because of a bad alternator, or the boost starts to creep for some reason. Now you are pushing more air than the pump can support and the car starts running lean. At that point there is a chance of melting something, which we would all like to avoid.
Also, please note that these flow rates are calculated at the fuel pump outlet and not after traveling through the system. Just another reason not to try and approach the maximum limits listed above.
