delta448
DSM Wiseman
- 3,626
- 315
- Jan 13, 2006
Waynesburg,
Pennsylvania
Since when do you even come close to similar brake heat from extended road course work that you would on a drag strip?
When you have to navigate turns AND straights to complete a lap, you stress the brakes more than just one time really hard.
If you start with a cold rotor and heat load it heavily one time every 20 minutes, the rotor can be thin, light, even scalloped since the one-time heating is not going to be able to warp the rotor.
Now, if you start with the same regular cold rotor and subject it to repetitive moderate heat loading from one turn to the next on a road course, shoving on the pedal hard once every 5 seconds or less, a thin rotor will not be able to dissipate heat quickly enough.
You might heat load the rotor less heavily each individual time compared to stopping a powerful drag car at 1/4 mile speed, but when you add 250*F or more at every turn, and don't have the surface area and material volume to shed more than 50*F between braking episodes, it won't take very long to heat soak everything and cause problems.
Ever see a car with a sticking caliper?
