skyrone
- 230
- 1
- Jul 12, 2007
Gillette,
Wyoming
Alright guys so my car has been sitting for two years. it had a short forever in the ignition circuit. Found the short and now I can not get a starter to crank in the car at all. I have changed the battery, unhooked my alternator, checked all my fuses idk whats going on. I have replaced the starter solenoid, the ignition switch, and am still getting no crank or clicks. I relocated the battery to the trunk using 0 gauge wire and have no voltage drop from the battery to the starter. Checked all my connections and ohmed out my terminals and my splice where the hot wire from the trunk connects to the old battery wires and everything tests good. I have relocated my batt ground and old battery ground a couple times to get better deeper grounds and still just not having any luck. I have gotten it to crank a little better by jumpin the solenoid with a wrench but still nothing promising. The engine turns like cake with the ratchet. This is like my 5th starter I've put in this thing and it bench tested fine. I need to get this beast running again before christmas or else shes getting parted out. Please help me if ya can. Hopin luv2ralleye is still around, he was always my go to wiring guy. been out of the game pretty much the 2 years my car hasnt been running. Thanks for any and all help.
